Brief Description: Match drilled wing tip extensions and worked on el
Spent time today finally match drilling the wing tip extension for the lighting and also worked on all the molex connectors and ground wires for the wing tip lights. Went very well with only minor mistakes that were easily corrected (choose wrong screws at one point also picked an incorrect molex connector). Tested both lights with the new molex connectors and they work perfectly.
