Brent Connelly - N913BC
Date:  10-19-2011
Number of Hours:  2.50
Manual Reference:  17-03
Brief Description:  Clecoed last of the large skins to the left wing
Finished deburing and priming the last two left wing skins and clecoed both to the top of the wing. Spencer came out to help get the last one inserted correctly to the wing. Decided to go ahead and cleco both of the skins before doing any riveting - the plans suggest doing some riveting after each skin is attached, but I have enough clecos to do it this way.
Also attached the wing doubler skin to see how it fits. As I've read on other sites, I'll need to remove it and bend the leading edge a little before finally riveting it. The fit is actually quite good now but it will need a little work.
All major skins now attached to left wing
