Brent Connelly - N913BC
Date:  10-15-2011
Number of Hours:  3.50
Manual Reference:  17-02 & 17-04
Brief Description:  Prepared W-1202-L skin
Prepared the W-1202-L skin, deburring the edges, rivet holes etc... Also decided to add the K-1100 nutplates and prime the access panel that the manual says should be done after the skin is riveted to the wing. I figured it would be easier to do that prior to attaching it to the ribs.
I used a tap to clean out the nutplate holes as suggested in an EAA tips for homebuilders video. The screws were much more easily inserted into the the nutplate that I've experienced before and I'll certainly use taps on all my future nutplate installations.
W-1202-L skin
W-1202-L skin
Mostly clecoed to the wing
Access panel to gain access to the stall warning assembly in left wing
