Brent Connelly - N913BC
Date:  8-18-2011
Number of Hours:  3.00
Manual Reference:  14-02
Brief Description:  Riveting of Hinge Assembly and Hinge Brackets
Began riveting all the parts I've been preping and priming in recent days. Unfortunately, I am just not satisfied with the W-1212 hinge assembly. The bearing is just not held as tightly in the assembly as I would have liked it. I drilled out the rivets once and re-did it but I still don't like one of the two.
Will likely order some replacement parts from Vans and redo the hinge. Probably ok, but I just don't like the look of it.
Hinge Bracket Assemblies
Problematic hinge assembly
Preped and primed rear spar doublers
