Completed priming, riveting and assembling the trim/servo assembly to the tailcone. Not easy to put together all the different washers and other hardware, but all went well. Also added the connectors to the servo control wire.
Decided to complete assembly of this section before attaching the stabilator to the tailcone. I'll do that down the road (probably in hanger at airport). I wanted to complete as much as I can here at home.
Tested the servo motor with a hand drill battery and it worked perfectly.
