Brent Connelly - N913BC
Date:  6-17-2011
Number of Hours:  3.00
Manual Reference:  10-80
Brief Description:  Trim wire and static system install
Began successful install of the trim wire along the left side of the inside tailcone. No issues.
Then the fun started. Due to a combination of not reading the instructions close enough and being in a hurry for no good reason, I managed to break one of the small plastic tips on the tee that attaches all three of the plastic tubes together. I was trying to adjust its position, but was pulling on the wrong part to be doing that. After quickly checking in at Home Depot and Lowes to see if they had anything similar to connect together these small plastic tubes and finding out that they didn't, I called Vans and ordered a couple of replacements. Good news is that they are only 80 cents each but I will have to wait a week or so until they arrive to finish the static system.
I have plenty of other prep work to do in the meanwhile, but I was really hoping to stay on track and get this static system install behind me.
Trim wires exiting the tailcone
Place where plastic tee should join together several static system tubes
String and extra tubes taped to inside of tailcone
