Brief Description: Measured and glued washers for F-1211 assembly to
Spent more time than planed, fitting and gluing the washers to the hinge brackets to ensure a smooth fit forthe F-12ll assembly. Very difficult to fit the washers into the small space in the hinge. Initially used larger washers than were appropriate and had to remove one with scraper and hammer after I glued it. Another one (correct size) came lose and needed to be re-glued.
In the end, the fit was tight and the washers were firmly in place. Used Boelube on the bolts and left them in place as the plans called for.
