Completely inventoried the kit box. My daughter Hillary helped call out the tag numbers and store the parts in my two overhead lofts and hardware organizer. Labelled about thirty draws for most of the hardware. Having several different sized screws or washers in the same small bag was not the easiest thing to sort through.
Only two pieces appear to be missing and will contact Vans to replace. Anti servo tab spars HS-1219 R & L. Otherwise everything was there as promised. Took over three hours to go through the entire kit.
