William's Web site
Date:  5-7-2009
Brief Description:  Engine Runs
First engine run (5 min) - Tested both Pmags 100 RPM drop each. Cycled the prop 3-5 times. No leaks found after run.
Changed oil and filter per Lycoming manual.
Second engine run (3 min) - Tested Pmags again, this time checked internal generator. Both check good. Vycled prop 3-5 times. No leaks found after run.
