Brief Description: Interior and more electrical problems
My dimmer switches were not working properly and I quickly (this time) discovered another grounding issue. There was discontinutiy in the grounds for the dimmer switches. I made another harness and when propperly grounded everything worked as is should. Installed a blue LED strip in the footwell on a dimmer.
I continued the install of the side panels which is quite involved. The kit includes nice templates that guide all the drilling that needs to be done. I am about to start actually putting the panels in. I put on the pushrods for the ailerons in order to close up everything under the floorboards in preparation for finishing the interior.
