Brians Web Site
Date:  8-23-2019
Number of Hours:  4.00
Brief Description:  Modifying QB fuse for tricyle gear
Had to enlarge various holes in the fuse for the trigear version. Drilled out the temporary pop rivets in the underside of the fuse in preparation for joining the two halves. Put on the nutplates for the gear-to-fuselage fairing attachment. Put in the lower gear braces and torqued the bolts. Worked to put together small fuselage parts for later.
Drilling out pop rivets
Lower gear brace
Lower gear brace
Seatbelt attach points and vent braces
