Brians Web Site
Date:  5-4-2019
Number of Hours:  4.50
Brief Description:  Finished trailing edge and trim servo mounting
Finished trailing edge riveting using the special dies from Cleaveland Tool. Made the job easy. Mounted the trim tab and servo. Tested the trim tab with a 9 volt battery - works as it should.
Trailing edge riveting
Hinge wire
Hinge wire
Testing the servo
Testing the servo
