Bruce & Kathy's RV-7A
Date:  12-12-2006
Number of Hours:  1.70
Brief Description:  Sanded HS to final
Saw this technique on American Hot Rod. After all the fiberglass work was laid out and the sanding was completed, you just take a hack saw blade and slowwwwly cut the resin. It is very thin and then sand to a smooth finish after you take the elevators off.
Now to cut the seam. Saw with metal blade. NOT !!!!
Hack saw blade.
Hack saw blade.
Fits perfect.
Fits perfect.
