I found out after drilling one of the rivets out 3 times that it is a lot easier to back rivet these into place. It made it very simple to do it that way so I will do it on the LT side. Also you can install these when you are installing all the other platenuts. Don't know why they tell you to do it 50 pages down in the manual. Checking if you are reading it I guess !!!!!!!
