Thought I would just square the spacer around the hole. Figured out AFTER I drilled all the holes that you still need to put it on the spar to push it to the middle. It was off about a l6th so I took it to the grinder. What a pain. Also using the side clamps to do the platenuts on the drill press was the way to go with this.
