Bruce & Kathy's RV-7A
RV 7A
Leading Edge Joint
I found that the marks on the tank joint on the outside view was good. Previous pic but was having problems with the rib so I took the rib out and put a mark on the inside too. Then I took the mallet to it to get it to fit at the top.
Field of clecos
Inside Tank Joint
Tank Joint done
RV 7A Home
2354
Empannage
FIBERGLASS
FINISH KIT
282
897
FLYING
FLYING
FUSELAGE
131
406
HANGAR
HORIZONTAL STAB
LEFT ELEVATOR
MISC
PAINTING
PANEL
PARTS- AIRPLANE
POLISHING
PRIMING
RIGHT ELEVATOR
RUDDER
Shop
SHOP SUPPLIES
TOOLS
TRIM TAB
VERTICAL STAB
WINGS
142
431
