As you can see in the photos that the best way to apply this primer is to keep it as flat as you can and apply light coats. These turned out 100% better than the HS and elevators. I will sand them down and see if I can get them to cover like these. Kinda of cool in the garage at 60 so I will take it slow tomorrow and see if it will work. Should be 54 tomorrow so I will wait till then.
