Bruce & Kathy's RV-7A
RV 7A
Rivet Right wing tip an inside
Rivet right wing tip and inside also installed nutplates for the emp fairingtapped out the nutplates , drilled out 5 holes for oops rivets on right wingtop. Put 2 rivets in leading edge of HS tips with no hole.
Problem
Solution--NO HOLE
Results kind of blurry
RV 7A Home
2354
Empannage
FIBERGLASS
FINISH KIT
282
897
FLYING
FLYING
FUSELAGE
131
406
HANGAR
HORIZONTAL STAB
LEFT ELEVATOR
MISC
PAINTING
PANEL
PARTS- AIRPLANE
POLISHING
PRIMING
RIGHT ELEVATOR
RUDDER
Shop
SHOP SUPPLIES
TOOLS
TRIM TAB
VERTICAL STAB
WINGS
142
431
