Brief Description: DRDT-2 Dual Purpose Table Construction
I put lag bolts thru a 2x8 to use as a vise and also for storage that will come up in later pictures. Also I used slip sheets and old carpet to slide the skins on. After youare finished with the table you can store the -2 upside down and clamp down.The tables are 51" x 36" eachTotal is 105" x 36" with the -2 in the middle.Total height is 42"
