Mikes Web Site
Date:  12-20-2006
Number of Hours:  5.00
Brief Description:  more fuselage panels
Finished nutplates on the left console. Drilled and run the battery to firewall cable. installed the electric flap motor. Test run the flap motor. The actuator rod gets hung up on the arm rest hole. It seems the hole is not big enough. Worked the hole, and retested. Works great. Drilled and cs'd for the flap block AN3's. the most aft cannot be riveted properly. I will be changing to cherry rivets for the aft nutplates.
