Mikes Web Site
Date:  6-11-2006
Number of Hours:  2.50
Manual Reference:  section 6
Brief Description:  Front Spar Assembly
assembled the front spar assembly.problem with HS-810 and 814,,, the "trimming" wasn't as nice as i would have like,, but it will do. There is still enough material for safe riveting.little goof after the hs810 and 814 were "bent" to fit the spar channel... I bent them the wrong way DOH!!... watch this folks... little bit of magic and they were bent back to the required 6 degrees..on to the ribs
