Brief Description: Misc loose ends on gear and wingtip
This afternoon I bedded in the front end of the wheel pants. I applied a fiberglass cloth and then applied a cotton flox/epoxy mixture. I then installed a plate nut for the upper gear fairing in the fuselage. That one was a tricky one under the lower longeron.
I then sanded down the wingtip and then applied two more layers of fiberglass. Taking the time to make it look good.
