Worked on the left wheel pant today. I aligned the wheel pant so that it was parallel with the axis of the aircraft and level. I used the laser and aligned with the nutplate and installed the wheel pant. I marked the laser on the wheel pant. Drilled the hole, repeat, repeat. I then mixed up an epoxy and cotton flox batch and bedded in the six holes on the rear half of the wheel pant.
