Pauls Web Site
RV-6A
Gear
6-12-2015
Right gear brake line
I installed the right gear brake line to the fuselage. I plan to use aluminum tubing instead of the plastic tubing. I also drilled the cotter pin hole in the wheel nut. Just followed the plans. No real big deal.
Drilled hole for right brake line
Drilled hole for right brake line bottom view
Flaring right brake line
RV-6A Home
2177
534
202
363
384
Gear
62
174
376
