Pauls Web Site
Date:  5-31-2015
Brief Description:  Right brake lines
Worked on getting the brake lines lined out. Had to disassemble the brakes to install the 90 degree fitting. I also had to remove the wheel and wheel pant bracket to get enough room to get the flaring tool in. I did the thing that everyone warns you not to do. I flared the tube without installing the nut and ferrel.
Assembling brake fittings
Flared the fitting without the nut and ferrel
Redone right
Redone right
