Brief Description: Removing engine mount from airframe
My plan has evolved to remove the engine/mount combo from the aircraft and dress it out on the ground. I added the backup alternator, engine ignition coils and oil cooler return fitting. I neglected taking more pictures this evening. Will have to snap some more tomorrow. I bolted everything on to make sure they fit together and then removed all of the components so that all of the gasket faces could be cleaned properly before final installation.
