Pauls Web Site
Date:  11-23-2014
Number of Hours:  4.00
Brief Description:  Right wing root fitting
I spent the afternoon pulling the wing back out slightly and making a template for drilling through the existing 1/8" hole. Also laid out for the 11 platenuts that have to be installed on the underside of the wing to the fuselage belly extension. Once I get the rear spar drilled I can drill these hole before I remove the wing again. This took awhile because I poured over the drawings.
