Pauls Web Site
Date:  11-22-2014
Brief Description:  Studied construction manual
I am getting set up to drill the rear spar holes that bolt the wing to the fuselage. I poured over the drawings and construction manual until I can recite it. I have to remove the wing slightly so that I can make a pattern of the pilot hole that is already drilled into the wing rear spar. When the wing is on the hole is covered. I need to make sure that the hole that I drill encompasses this hole.
