It is kind of boring taking pictures of wiring. Below is a couple of pictures of flap motor and position sensor wiring. The second picture is in the tunnel just aft of the main spar. The last picture is one of about 15 electrical drawings. This one is the main drawing. The rest are system specific. I highlight each wire as it is run. Each wire is labeled exactly as it is on the drawing. I use a Dymo that labels heat shrink tubing.
