I am finishing up the wings and gear. I spent the evening marking all drilled holes that need to be dimpled or countersunk after I remove the wings. I marke all holes on the gear leg fairings on the bottom of the skin. There is lot to do under there once the wings come off and it will be easy to get the holes mixed up. While doing this I had to add some fiberglass to one of the gear fairings to accomodate an existing fastener. I also removed the main gear from the aircraft.
