Pauls Web Site
Date:  6-12-2015
Number of Hours:  1.00
Brief Description:  More right brake line pictures
I also received my package from Aircraft Spruce. It had the replacement bolt for the front spar bolt. I drilled the hole for the safety wire. I did not install the cotter pin or the safety wire because I know that I will have to remove the wings once my gear is complete. I will install after I reassemble at the airport.
Right brake line installed
Right brake line front view
Replaced bolt to AN4H-7 and drilled safety wire hole
