Pauls Web Site
Date:  6-12-2015
Number of Hours:  5.00
Brief Description:  Right wheel pant
I installed the right wheel pant today and there were previous holes drilled in it for mounting it to the wheel. I measured the distance from the back and the front to the center of the aircraft reference line and the back end was 1/4" in. To fix this I removed the pants and sanded down all of the holes and proceeded to apply layers of fiberglass to fill in the voids. This took two applications. I used the West's fast hardener and set them out in the sun. They would cure in 3 hours. During the cure time I worked on the brake lines.
