Finish priming the parts. I was planning on priming the inside of the skins. I decided against it because the process is so messy and will add very little to my corrosion prevention. So I remove the clear packing tape I used to plug the holes in the skin and protect the outer surface. The tape left a thick layer of glue behind. This stuff is EVIL!!! I have to find a way to remove this without scratching the surface. Those behind me....do not use this!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
