N750MC Construction Log
Date:  5-6-2009
Number of Hours:  3.00
Brief Description:  Elevator work continues
Made progress on the elevator spar center section. This task was accomplished by drilling a few holes at a time while the assembly was clamped to the flat work surface and flipping the elevator over several times until all holes were drilled to the final #20 size. All holes are now drilled and the elevator left and right sides are aligned as they should be.
