Brief Description: Installed three of the seat belt fittings
I cleaned the all bonding surfaces and the bolt shanks with an acetone wipe. I then mixed up some pure epoxy and pretreated all of the drilled holes and counterbores. Next I mixed up wet flox and applied to the backside of the fittings and the bolt shanks. I then tightened the bolts until the flox squeeze out stopped. Then I cleaned up the squeeze out with a rag and acetone. I also partially filled the bolt holes with left over wet flox. I will finish the fill with dry micro becuase it will sand better next to the soft foam around the holes.
