BILL'S WEB SITE
Date:  11-4-2017
Brief Description:  Fitting Firewall to Fuselage Side
Squared up the fuselage longeron openings with a perma grit file, lots of back and forth to check fit. Once I had the top pieces fitting well I marked the lower longeron postion in place. I then drilled small holes around the inside of the markings. A razor saw was used to connect the dots and make the rough cut. I then used a file to get out to the markings. Again lots of back and forth to get the fit correct. This tool about an hour per fuselage side.
Working the Lower Longeron after marking in position on fuselage side
Fit in Place
Fit in Place
Inside View
Inside View
