BILL'S WEB SITE
Date:  7-1-2018
Number of Hours:  3.50
Brief Description:  Fuselage Clean Up and Bottom Foam Blank
I decided to pull the remaining peel ply from the fuselage sides, cleaned up all the peel ply and tape edges using a DA and hand sanding. I figured all of this clean up would be much easier to reach before putting on the fuselage bottom. I then took a long sanding board and squared up the bottom edges of the longerons so they were nice and flat. This took minimal work and will allow the bottom skin to fit well with minimal gaps. I cleaned up the joint on the bottom foam piece from a couple of days.
Fuselat Bottom clamped in position and squared up
