Finally got back out to the shop and took some measurements on the overall strainghtness and squareness of the fuselage assembly. Actually looked quite close considering I did not really try very hard. I also noted that my forward seat bulkhead extends a little above the fuselage upper longerons when the bottom is flush with the lower longerons. I marked this with a pen, it is about 1/8 of an inch that will need to be trimmed off. I then marked the fuselage sides for where the peel ply will need to be removed to make the BID tape joints afer assembly.
View of Front Seat Bulkhead protruding past upper longerons (remember it is upside down!)
