BILL'S WEB SITE
Date:  12-3-2017
Number of Hours:  6.50
Brief Description:  Landing Gear Attach Brackets - Final Shaping
Today I finished shaping the landing gear attach brackets. I cut the fwd bracket bases to the scribe lines using my table saw with a metal blade. I then finished those up with sanders and files until they were smooth and fit in position flush with the fuselage wood. I then marked for the mounting holes. To get the holes centered in the fuselage wood I measured the width of the fuselage wood and marked half of that from the freshly cut bases of the forward brackets. I drilled the mounting holes and the lightening hole on my mini-mill. I then marked the ears for trimming. I measured the AN6 bolt hole edge distance to the edge of the 2.00 angle. I used this dimension to scribe an arc around the hole. I then used a straight edge to go from the base plate edge to the tangent of the scribed arc. I trimmed the bulk of the material off using my band saw and then used my belt sander to finish them up. I then turned my focus to the aft brackets. I used poster board patterns to scribe the curved shapes on the angle legs. I used the band saw, belt sanders, drum sanders, files, sand paper, etc until I had the shapes cut and smoothed. I have a spot face coming tomorrow which will allow me to spot face the hole that are closest to the vertical angles. Then on to alodine and pressing in the steel bushings.
Cutting angles on the table saw
All done for the day
In place on the fuselage
