BILL'S WEB SITE
Date:  10-17-2017
Number of Hours:  1.75
Brief Description:  LH Fuselage Side final trimming and RH Fuselage Si
Spent about 45 minutes after work measuring out the AFT landing gear brackets from the plans book and adjusted my Solid Works model to match. Made a couple of full scale plots to assist in my fabrication.
I then grabbed the RH fuselage side from the house and trimmed up the longerons and aft foam insert. I then mixed up a little micro and added a fillet between the lower longeron and the fuselage inner skin. I did this with a ziplog icing bag and formed it with popsicle stick.
Micro Fillet to make a smooth transition for the later layups
Micro close up
Micro close up
Aft Landing Gear Attach Fitting Drawing
