Brief Description: RH Fuselage Side -Trimmed Upper Longeron Layups
I trimmed the upper longeron layups I did last night using my palm router with a pattern bit. Then I sanded the aft fuselage foam insert flush with the lower longeron/doubler and LWX and LWY, nice and flat! I trimmed the upper and lower longerons and LWX to about 1 inch past where the firewall will attach. I did this with the Fein tool. I also trimmed up the foam insert flush with the bottom core.
Upper Longeron Layups Trimmed - Landing gear angles in the foreground
