BILL'S WEB SITE
Date:  10-15-2017
Number of Hours:  3.00
Brief Description:  RH Fuselage Side - Top Longeron Layups
Used my router to put a 3/16" radius on the top longeron to ease layups. Applied the 3 UNI plys over the longeron section with the tapered doubler, One ply of BID runs the full longeron length. This was done with two pieces of cloth with a overlap seam in the middle. I peel plyed after complete. I used one piece of peel ply to go from the inner skin up the vertical of the longeron and then a separate peice to go over the inside vertical surface. This can been seen in photo two, note the red tracer thread orientation.
RH Fuselage Top Longeron layups complete
Front of Longeron -Peep Ply in place
Transition of Doubler, Flox radius noticeable here
