Brief Description: RH Fuselage Side LWX and LWY Bonding
Final trimmed LWX and LWY wood and set up a clamping/positioning scheme. I bonded the wood peices into place and clamped and weighted them in place. I mixed up 20 grams of resin for this. This was just enough to include precoating the wood with pure epoxy before making up the wet flox for bonding
WARNING - The dimensions on the spar spacer are wrong! Should be 6.5 x 8.5, the one in the picture is WRONG. I had to redo this area, do to this error.
Note sliding wedge clamps applying presure to hold th horizontal piece against the CS Spar Spacer
Weight holding the wood down
Another view. This shows the stop blocks screwed to the table to hold the CS Spacer and the wood.
