Rob and I layed up the two plys ofUNI on the RH fuselage side inner skin. Same as the LH side. You can see the dark lines are are the 30 degree reference lines at the ply intersections. Getting the uni down in the control stick recess was difficult but it stayed down eventually! I peel plyed the recess with two inch wide strips before covering the entire side with peel ply. You can see the red tracers of the strips underneth the full peel ply. Resin estimates from the LH side were pretty close. Probably mixed up a little more, but threw away more also.
RH Fuselage side from firewall side looking forward
Peel Ply over control stick carve our - Peel ply strips below
