Set up my new epoxy pump. Spent some time moving my resin and hardener into the new Sticky Stuff epoxy pump. The mix ratio is adjusted by changing the arm length on the hardener pump. I had to increase the amount of hardener to get the desired 100:40 ratio (by weight). I used my gram scale to make these adjustment. It took be about six tries to get it perfect. Test shots after that were perfect and consistent to the gram!
