BILL'S WEB SITE
Date:  7-7-2008
Number of Hours:  3.00
Brief Description:  Fabricate Engine cowling
11. Fabricate Engine Cowling
EXTRA CREDIT
8 parts
2 small naca scoops
1 large naca scoop
4 walls airducting
25 lbs total
evolution from custom fabricated toward standardized.
have to custom cut the openings for the exhaust because the engines are slightly different.
Now most fittings are cut or drilled from templates. Improvements in ducting have decreased weight from 60+ to about 25 lbs.
cut openings for naco scoop
gouge out foam core about 1/16", fill with bondo for smooth flush finish.
glue scoop to cowling.
drill out spring clip holes
front two are screw fittings for greater strength.
Installing induction
Performing layup for induction
smoothing edges
smoothing edges
