BILL'S WEB SITE
Date:  7-10-2008
Brief Description:  Install control yoke
2. Install Instrument Panel and Instruments
Carry yoke into plane
lay on back, insert aileron cables through pulleys. attech to sectors. safety wire screw to sector. re-install cable guard onto pulleys.
clear insulation from mounting plate on firewall.
push yoke flush with plates on both sides.
top two bolts on each side enter from inside.
bottom bolts outside in, countersunk flush. torque 40 ft lbs (all six)
attach outer legs to cross brace on floor, torque 40 ft lbs
attach elevator cables to elevator, reinstall cable guard.
carry yoke into plane
insert cable through pulley
push yoke flush with mounting plates
