BILL'S WEB SITE
Date:  7-22-2008
Brief Description:  Install Cables, Wires, and Lines
12. Install Cables, Wires, and Lines
adjust push rod so that, with bell crank pinned in neutral, aileron lines up with flap line
disconnect cross plane aileron cable
adjust bellcrank stops to achieve the following smart sensor measurements
up - 23.5 degrees
down 18 degrees
reconnect cable
do same to co-pilot side
co-pilot - found 1/4" gap between trailing edge of flap and aileron
Install aileron cable
threading aileron cable
secure cable on bellcrank
