BILL'S WEB SITE
Date:  11-20-2008
Number of Hours:  12.00
Manual Reference:  26.3
Brief Description:  Install Propeller
14. Install Propeller
unpack prop, remove strapping and cardboard
position prop horizontal on stand (big garbage can)
wrap strap around base of prop
lift with hoist until facing plane, keeping lower prop blade clear of floor
shorten post (beta lever bracket) on base to avoid hitting prop
align bolt flange with posts on engine mounting plate
insert until snug
hand tighten 12 bolts with slotted washers
torque, in marked sequence, to 40', then 80', then 105 in circular pattern
Lift propellor in position
line up hub into engine mount
Torquing propellor install bolts
