Brief Description: Install Cables, Wires, and Lines
12. Install Cables, Wires, and Lines
adjust push rod so that, with bell crank pinned in neutral, aileron lines up with flap line disconnect cross plane aileron cable adjust bellcrank stops to achieve the following smart sensor measurements up - 23.5 degrees down 18 degrees reconnect cable do same to co-pilot side
co-pilot - found 1/4" gap between trailing edge of flap and aileron
